楼主 #1 2020-04-12 11:27:27
zhanshi445
请教各位大佬,tiny200v2怎么修改uboot打印串口为uart1
照着 https://whycan.cn/t_3138.html 该帖子学f1c200s,但tiny200v2的打印串口和licheepi nano的不同,需要修改为uart1,我照着一些帖子改了dts sunxi-common.h等文件,还是没有成功。linux新手,请各位帮看下还有哪些需要改
/u-boot/include/configs/sunxi-common.h
#ifndef CONFIG_CONS_INDEX
#define CONFIG_CONS_INDEX 2
#ifdef CONFIG_REQUIRE_SERIAL_CONSOLE
#if CONFIG_CONS_INDEX == 1
#ifdef CONFIG_MACH_SUN9I
#define OF_STDOUT_PATH		"/soc/serial@07000000:115200"
#else
#define OF_STDOUT_PATH		"/soc@01c00000/serial@01c28000:115200"
#elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUN5I)
#define OF_STDOUT_PATH		"/soc@01c00000/serial@01c28400:115200"
#elif CONFIG_CONS_INDEX == 3 && defined(CONFIG_MACH_SUN8I)
#define OF_STDOUT_PATH		"/soc@01c00000/serial@01c28800:115200"
#elif CONFIG_CONS_INDEX == 5 && defined(CONFIG_MACH_SUN8I)
#define OF_STDOUT_PATH		"/soc@01c00000/serial@01f02800:115200"
#else
#error Unsupported console port nr. Please fix stdout-path in sunxi-common.h.
#endif /* ifdef CONFIG_REQUIRE_SERIAL_CONSOLE */
\u-boot\arch\arm\dts\suniv.dtsi
			uart0_pins_a: uart-pins-pe {
				pins = "PE0", "PE1";
				function = "uart0";
			uart1_pins_a: uart-pins-pa {
				pins = "PA2", "PA3";
				function = "uart1";
uart0: serial@1c25000 {
			compatible = "snps,dw-apb-uart";
			reg = <0x01c25000 0x400>;
			interrupts = <1>;
			reg-shift = <2>;
			reg-io-width = <4>;
			clocks = <&ccu CLK_BUS_UART0>;
			resets = <&ccu RST_BUS_UART0>;
			status = "disabled";
		uart1: serial@1c25400 {
			reg = <0x01c25400 0x400>;
			interrupts = <2>;
			reg-shift = <2>;
			reg-io-width = <4>;
			clocks = <&ccu CLK_BUS_UART1>;
			resets = <&ccu RST_BUS_UART1>;
			status = "enabled";
\u-boot\arch\arm\dts\suniv-f1c100s-licheepi-nano.dts
aliases {
		serial0 = &uart0;
		spi0 = &spi0;
		serial1 = &uart1;
	chosen {
		stdout-path = "serial1:115200n8";
&uart0 {
	pinctrl-names = "default";
	pinctrl-0 = <&uart0_pins_a>;
	status = "okay";
&uart1 {
	pinctrl-0 = <&uart1_pins_a>;
	status = "okay";
楼主 #2 2020-04-12 11:31:02
zhanshi445
Re: 请教各位大佬,tiny200v2怎么修改uboot打印串口为uart1
\u-boot\arch\arm\mach-sunxi\board.c
#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUNIV)
	sunxi_gpio_set_cfgpin(SUNXI_GPE(0), SUNIV_GPE_UART0);
	sunxi_gpio_set_cfgpin(SUNXI_GPE(1), SUNIV_GPE_UART0);
	sunxi_gpio_set_pull(SUNXI_GPE(1), SUNXI_GPIO_PULL_UP);
#elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUNIV)
	sunxi_gpio_set_cfgpin(SUNXI_GPA(2), SUNIV_GPA_UART1);
	sunxi_gpio_set_cfgpin(SUNXI_GPA(3), SUNIV_GPA_UART1);
	sunxi_gpio_set_pull(SUNXI_GPA(3), SUNXI_GPIO_PULL_UP);
#elif CONFIG_CONS_INDEX == 1 && (defined(CONFIG_MACH_SUN4I) || \
				 defined(CONFIG_MACH_SUN7I) || \
				 defined(CONFIG_MACH_SUN8I_R40))
#3 2020-04-12 11:45:51
有梦的地方
已发帖子: 284
照这个帖子,药到病除: https://whycan.cn/t_4017.html#p37402
楼主 #4 2020-04-12 11:48:46
zhanshi445
就是照着这个帖子改的,还是不行
#5 2020-04-12 11:51:56
有梦的地方
已发帖子: 284
zhanshi445 wrote:
就是照着这个帖子改的,还是不行
那现在是什么情况呢?串口一点输出都没有吗?cp2104?
楼主 #6 2020-04-12 11:56:09
zhanshi445
对,是CP2104,串口什么输出都没有,芯片应该是正常的,烧过其它固件
#7 2020-04-12 12:38:49
已发帖子: 857
固件不好改,可以考虑改硬件,好像widora保留了修改的方法。看下图:
楼主 #8 2020-04-12 12:45:14
zhanshi445
/files/members/1315/none_20200412-1238.png
现在手上没工具,只能在软件上想办法
#9 2020-04-12 15:02:06
迪卡
所在地: 河北
已发帖子: 916
按照5楼的来
如果你需要UART1 那么其他的不要写。
#10 2020-04-12 21:18:02
MK-2020
已发帖子: 51
按照上面的写法,你去看下autoconf.h,可能CONFIG_CONS_INDEX = 1
把上面试下改为:
#undef CONFIG_CONS_INDEX
说不定有惊喜。
楼主 #11 2020-04-13 00:57:02
zhanshi445
把上面试下改为:
说不定有惊喜。
真的有惊喜。。。。。这个我之前我照着改过,会报错,刚看到你的回复想到可以把这两条语句放到后面,这样就不会报无端口的错误了
#12 2020-04-16 19:16:30
liuchangyin
已发帖子: 204
把上面试下改为:
说不定有惊喜。
big_smile
#13 2020-04-23 22:37:24
motata
我传个改好的NorFlash的固件, root登陆,密码:123,分辨率是480*272的。Tiny200SV2_uart1_480x272_spiflash_root_123.rar
#14 2020-04-24 19:36:05
sean68
应该在sys_config.fex里面改
#15 2020-05-01 19:46:31
zwanh
我也是tiny200,我在修改u-boot的串口,改了arch/arm/mach-sunxi/clock_sun6i.c和arch/arm/mach-sunxi/board.c,但还是不能正常使用,感觉是串口没有配置为UART1,但是不知道在哪里配置,谁能告诉下
楼主 #16 2020-05-01 20:04:33
zhanshi445
看上面的连接,基本都有了
#17 2020-05-01 21:23:57
Laoyuan
UART是需要TTL转USB吗
#18 2020-05-03 21:35:16
zwanh
zhanshi445 wrote:
看上面的连接,基本都有了
谢谢,按照上面的相关教程,已经完全可以了
