楼主 #1 2019-09-03 17:23:33
阿黄
已发帖子: 299
请教F1C100S的UART2_RX(PD14)无法接收数据的问题
很奇怪,设备树中配置了串口0、串口1、串口2,串口0和串口1都可以正常收发,串口2只能发送,无法接收到数据,接收引脚上有波形。
                        uart0_pins_a: uart-pins-pe {
				pins = "PE0", "PE1";
				function = "uart0";
			uart1_pins_a: uart-pins-pd {
				pins = "PD3", "PD4";
				function = "uart1";
			uart2_pins_a: uart2-pins-pd {
				pins = "PD14", "PD13";
				function = "uart2";
经过排查,发现PD14脚的复用功能并未生效,PD14还是禁用的状态(0x7),将其设置为0x3之后就可以收到数据了。
# devmem 0x01c20870
0x77377677
devmem 0x01c20870 32 0x73377677
设备树文件 suniv.dtsi
// SPDX-License-Identifier: (GPL-2.0+ OR X11)
 * Copyright 2018 Icenowy Zheng <icenowy@aosc.io>
#include <dt-bindings/clock/suniv-ccu.h>
#include <dt-bindings/reset/suniv-ccu.h>
	#address-cells = <1>;
	#size-cells = <1>;
	interrupt-parent = <&intc>;
	clocks {
		#size-cells = <1>;
		ranges;
		osc24M: clk-24M {
			#clock-cells = <0>;
			compatible = "fixed-clock";
			clock-frequency = <24000000>;
			clock-output-names = "osc24M";
		osc32k: clk-32k {
			#clock-cells = <0>;
			clock-frequency = <32768>;
			clock-output-names = "osc32k";
		fake100M: clk-100M {
			#clock-cells = <0>;
			clock-frequency = <100000000>;
			clock-output-names = "fake-100M";
	cpus {
		#address-cells = <0>;
		#size-cells = <0>;
		cpu {
			compatible = "arm,arm926ej-s";
			device_type = "cpu";
	de: display-engine {
		compatible = "allwinner,suniv-display-engine";
		allwinner,pipelines = <&fe0>;
		status = "disabled";
	soc {
		compatible = "simple-bus";
		#size-cells = <1>;
		ranges;
		sram-controller@1c00000 {
			compatible = "allwinner,sun4i-a10-sram-controller";
			reg = <0x01c00000 0x30>;
			#size-cells = <1>;
			ranges;
			sram_d: sram@10000 {
				compatible = "mmio-sram";
				reg = <0x00010000 0x1000>;
				#size-cells = <1>;
				ranges = <0 0x00010000 0x1000>;
				otg_sram: sram-section@0 {
					compatible = "allwinner,sun4i-a10-sram-d";
					reg = <0x0000 0x1000>;
		spi0: spi@1c05000 {
			compatible = "allwinner,suniv-spi",
				     "allwinner,sun8i-h3-spi";
			reg = <0x01c05000 0x1000>;
			interrupts = <10>;
			clocks = <&ccu CLK_BUS_SPI0>, <&ccu CLK_BUS_SPI0>;
			clock-names = "ahb", "mod";
			resets = <&ccu RST_BUS_SPI0>;
			#size-cells = <0>;
		spi1: spi@1c06000 {
			reg = <0x01c06000 0x1000>;
			interrupts = <11>;
			clocks = <&ccu CLK_BUS_SPI1>, <&ccu CLK_BUS_SPI1>;
			resets = <&ccu RST_BUS_SPI1>;
			#size-cells = <0>;
		tcon0: lcd-controller@1c0c000 {
			compatible = "allwinner,suniv-tcon";
			reg = <0x01c0c000 0x1000>;
			interrupts = <29>;
			clocks = <&ccu CLK_BUS_LCD>,
				 <&ccu CLK_TCON>,
				 <&osc24M>;	/* Still unknown */
				      "tcon-ch0",
				      "tcon-ch1";
			clock-output-names = "tcon-pixel-clock";
			resets = <&ccu RST_BUS_LCD>;
			reset-names = "lcd";
			ports {
				#size-cells = <0>;
				tcon0_in: port@0 {
					#size-cells = <0>;
					reg = <0>;
					tcon0_in_be0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&be0_out_tcon0>;
				tcon0_out: port@1 {
					#size-cells = <0>;
					reg = <1>;
		mmc0: mmc@1c0f000 {
			compatible = "allwinner,suniv-mmc",
				     "allwinner,sun7i-a20-mmc";
			reg = <0x01c0f000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC0>,
				 <&ccu CLK_MMC0>,
				 <&ccu CLK_MMC0_OUTPUT>,
				 <&ccu CLK_MMC0_SAMPLE>;
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC0>;
			reset-names = "ahb";
			interrupts = <23>;
			pinctrl-names = "default";
			pinctrl-0 = <&mmc0_pins>;
			#size-cells = <0>;
		mmc1: mmc@1c10000 {
			reg = <0x01c10000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC1>,
				 <&ccu CLK_MMC1>,
				 <&ccu CLK_MMC1_OUTPUT>,
				 <&ccu CLK_MMC1_SAMPLE>;
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC1>;
			interrupts = <24>;
			#size-cells = <0>;
		ccu: clock@1c20000 {
			compatible = "allwinner,suniv-ccu";
			reg = <0x01c20000 0x400>;
			clocks = <&osc24M>, <&osc32k>;
			clock-names = "hosc", "losc";
			#clock-cells = <1>;
			#reset-cells = <1>;
		intc: interrupt-controller@1c20400 {
			compatible = "allwinner,suniv-ic";
			reg = <0x01c20400 0x400>;
			interrupt-controller;
			#interrupt-cells = <1>;
		pio: pinctrl@1c20800 {
			compatible = "allwinner,suniv-pinctrl";
			reg = <0x01c20800 0x400>;
			interrupts = <38>, <39>, <40>;
			clocks = <&ccu CLK_BUS_PIO>, <&osc24M>, <&osc32k>;
			gpio-controller;
			#interrupt-cells = <3>;
			#gpio-cells = <3>;
			spi0_pins_a: spi0-pins-pc {
				pins = "PC0", "PC1", "PC2", "PC3";
				function = "spi0";
			spi1_pins_a: spi1-pins-pc {
				pins = "PE7", "PE8", "PE9", "PE10";
				function = "spi1";
			lcd_rgb666_pins: lcd-rgb666-pins {
				pins = "PD0", "PD1", "PD2", "PD3", "PD4",
				       "PD5", "PD6", "PD7", "PD8", "PD9",
				       "PD10", "PD11", "PD12", "PD13", "PD14",
				       "PD15", "PD16", "PD17", "PD18", "PD19",
				       "PD20", "PD21";
				function = "lcd";
				function = "uart0";
				function = "uart1";
				function = "uart2";
			mmc0_pins: mmc0-pins {
				pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
				function = "mmc0";
		        rtp_pins: rtp-pins {
			        pins = "PA0", "PA1", "PA2", "PA3";
			        function = "rtp";
			i2c0_pins: i2c0 {
				pins = "PE11", "PE12";
				function = "i2c0";
			i2c1_pins: i2c1 {
				pins = "PD5", "PD6";
				function = "i2c1";
			spi_int: spi_int {
				pins = "PE2";
		          	function = "gpio_in";
		timer@1c20c00 {
			compatible = "allwinner,suniv-timer";
			reg = <0x01c20c00 0x90>;
			interrupts = <13>;
			clocks = <&osc24M>;
		wdt: watchdog@1c20ca0 {
			compatible = "allwinner,sun6i-a31-wdt";
			reg = <0x01c20ca0 0x20>;
		rtp: rtp@1c24800 {
		    compatible = "allwinner,sun4i-a10-ts";
		    reg = <0x01c24800 0x100>;
		    interrupts = <20>;
		    allwinner,ts-attached;
		    #thermal-sensor-cells = <0>;
		    pinctrl-0 = <&rtp_pins>;
		uart0: serial@1c25000 {
			compatible = "snps,dw-apb-uart";
			reg = <0x01c25000 0x400>;
			interrupts = <1>;
			reg-shift = <2>;
			reg-io-width = <4>;
			clocks = <&ccu CLK_BUS_UART0>;
			resets = <&ccu RST_BUS_UART0>;
		uart1: serial@1c25400 {
			reg = <0x01c25400 0x400>;
			interrupts = <2>;
			reg-shift = <2>;
			reg-io-width = <4>;
			clocks = <&ccu CLK_BUS_UART1>;
			resets = <&ccu RST_BUS_UART1>;
		uart2: serial@1c25800 {
			reg = <0x01c25800 0x400>;
			interrupts = <3>;
			reg-shift = <2>;
			reg-io-width = <4>;
			clocks = <&ccu CLK_BUS_UART2>;
			resets = <&ccu RST_BUS_UART2>;
		i2c0: i2c@1C27000 {
                    reg = <0x01C27000 0x400>;
                    interrupts = <7>;
                    clocks = <&ccu CLK_BUS_I2C0>;
                    resets = <&ccu RST_BUS_I2C0>;
                    pinctrl-0 = <&i2c0_pins>;
                    #size-cells = <0>;
		i2c1: i2c@1C27400 {
                    reg = <0x01C27400 0x400>;
                    interrupts = <8>;
                    clocks = <&ccu CLK_BUS_I2C1>;
                    resets = <&ccu RST_BUS_I2C1>;
                    pinctrl-0 = <&i2c1_pins>;
                    #size-cells = <0>;
		usb_otg: usb@1c13000 {
			compatible = "allwinner,suniv-musb";
			reg = <0x01c13000 0x0400>;
			clocks = <&ccu CLK_BUS_OTG>;
			resets = <&ccu RST_BUS_OTG>;
			interrupts = <26>;
			interrupt-names = "mc";
			phys = <&usbphy 0>;
			phy-names = "usb";
			extcon = <&usbphy 0>;
			allwinner,sram = <&otg_sram 1>;
		usbphy: phy@1c13400 {
			compatible = "allwinner,suniv-usb-phy";
			reg = <0x01c13400 0x10>;
			reg-names = "phy_ctrl";
			clocks = <&ccu CLK_USB_PHY0>;
			clock-names = "usb0_phy";
			resets = <&ccu RST_USB_PHY0>;
			reset-names = "usb0_reset";
			#phy-cells = <1>;
		fe0: display-frontend@1e00000 {
			compatible = "allwinner,suniv-display-frontend";
			reg = <0x01e00000 0x20000>;
			interrupts = <30>;
			clocks = <&ccu CLK_BUS_DE_FE>, <&ccu CLK_DE_FE>,
				 <&ccu CLK_DRAM_DE_FE>;
			clock-names = "ahb", "mod",
				      "ram";
			resets = <&ccu RST_BUS_DE_FE>;
			ports {
				#size-cells = <0>;
				fe0_out: port@1 {
					#size-cells = <0>;
					reg = <1>;
					fe0_out_be0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&be0_in_fe0>;
		be0: display-backend@1e60000 {
			compatible = "allwinner,suniv-display-backend";
			reg = <0x01e60000 0x10000>;
			reg-names = "be";
			interrupts = <31>;
			clocks = <&ccu CLK_BUS_DE_BE>, <&ccu CLK_DE_BE>,
				 <&ccu CLK_DRAM_DE_BE>;
				      "ram";
			resets = <&ccu RST_BUS_DE_BE>;
			reset-names = "be";
			assigned-clocks = <&ccu CLK_DE_BE>;
			assigned-clock-rates = <300000000>;
			ports {
				#size-cells = <0>;
				be0_in: port@0 {
					#size-cells = <0>;
					reg = <0>;
					be0_in_fe0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&fe0_out_be0>;
				be0_out: port@1 {
					#size-cells = <0>;
					reg = <1>;
					be0_out_tcon0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&tcon0_in_be0>;
设备树 sunxi-f1c100s-nano.dts
/dts-v1/;
#include "suniv-f1c100s.dtsi"
#include <dt-bindings/gpio/gpio.h>
	model = "Lichee Pi Nano";
	compatible = "licheepi,licheepi-nano", "allwinner,suniv-f1c100s",
		     "allwinner,suniv";
	aliases {
		serial0 = &uart0;
		spi0 = &spi0;
	chosen {
		stdout-path = "serial0:115200n8";
	reg_vcc3v3: vcc3v3 {
		compatible = "regulator-fixed";
		regulator-name = "vcc3v3";
		regulator-min-microvolt = <3300000>;
		regulator-max-microvolt = <3300000>;
&otg_sram {
	status = "okay";
&pio {
    dm9051_default:dm9051_default{
    dm9051_rst:dm9051_rst{
	    pins = "PE3";
    dm9051_int:dm9051_int{
	    pins = "PE2";
/*&spi0 {
	pinctrl-0 = <&spi0_pins_a>;
	status = "okay";
	flash@0 {
		#size-cells = <1>;
		compatible = "winbond,w25q128", "jedec,spi-nor";
		reg = <0>;
		spi-max-frequency = <40000000>;
&spi0 {
    status = "okay";
    spi-max-frequency = <50000000>;
    flash: w25q128@0 {
        #size-cells = <1>;
        reg = <0>;
        partitions {
            compatible = "fixed-partitions";
            #size-cells = <1>;
            partition@0 {
                label = "u-boot";
                reg = <0x000000 0x70000>;
                read-only;
            partition@70000 {
                label = "dtb";
                reg = <0x70000 0x10000>;
                read-only;
            partition@80000 {
                label = "kernel";
                reg = <0x80000 0x400000>;
                read-only;
            partition@480000 {
                label = "rootfs";
                reg = <0x480000 0xB80000>;
&spi1 {
    pinctrl-0 = <&spi1_pins_a>;
    pinctrl-1 = <&spi1_pins_a>;
    status = "okay";
    spi-max-frequency = <25000000>;
    dm9051@0 {
        compatible = "davicom,dm9051";
        reg = <0>;
        spi-max-frequency = <25000000>;/*<109000000>;*/
	dm9051_rst = <&pio 4 3 GPIO_ACTIVE_HIGH>; /* PE3 */
	status = "okay";
&spi_int {
        interrupt-parent = <&pio>;
        interrupts = <39>; /* pe2 */
	status = "okay";
&i2c1 {
    clock_frequency = <400000>;
    status = "okay";
    rtc@51 {
	compatible = "nxp,pcf8563";
        reg = <0x51>;
	status = "okay";
&uart0 {
	pinctrl-0 = <&uart0_pins_a>;
	status = "okay";
&uart1 {
	pinctrl-0 = <&uart1_pins_a>;
	status = "okay";
&uart2 {
	pinctrl-0 = <&uart2_pins_a>;
	status = "okay";
&usb_otg {
	dr_mode = "otg";
	status = "okay";
&usbphy {
	usb0_id_det-gpio = <&pio 3 10 GPIO_ACTIVE_HIGH>; /* PD10 */
	status = "okay";
但是查了下设备树,唯一用到PD14的功能是rgb接口,但是并未启用。很奇怪为什么发送脚已经被正确设置了,接收脚却没有被正确设置复用。
#2 2019-09-03 18:02:50
Re: 请教F1C100S的UART2_RX(PD14)无法接收数据的问题
还有这么奇怪的问题, 晚点我再看看
楼主 #3 2019-09-08 17:54:22
阿黄
已发帖子: 299
LOG中有一句
[ 0.832283] 1c25400.serial: ttyS1 at MMIO 0x1c25400 (irq = 23, base_baud = 6250000) is a 16550A
[    0.841925] suniv-pinctrl 1c20800.pinctrl: unsupported function uart2 on pin PD14
[ 0.871149] 1c25800.serial: ttyS2 at MMIO 0x1c25800 (irq = 24, base_baud = 6250000) is a 16550A
[ 0.881947] SCSI Media Changer driver v0.25
回头查查pinctrl中是啥意思
#4 2019-09-08 18:45:49
pinctrl 是登记 soc 芯片上面所有引脚复用。
你先搜索一下哪个 pinctrl 文件参与了编译:
find . |grep pinctrl |grep \\.o$
然后看下 D14 是不是没有注册复用UART功能, 只注册了GPIO。
楼主 #5 2019-09-08 21:41:37
阿黄
已发帖子: 299
查过了,
./drivers/pinctrl/sunxi/pinctrl-suniv.c 中 第 207行
	SUNXI_PIN(SUNXI_PINCTRL_PIN(D, 14),
		  SUNXI_FUNCTION(0x0, "gpio_in"),
		  SUNXI_FUNCTION(0x1, "gpio_out"),
		  SUNXI_FUNCTION(0x2, "lcd"),		/* D20 */
		  SUNXI_FUNCTION(0x3, "lvds1"),		/* RX  这一行*/
		  SUNXI_FUNCTION_IRQ_BANK(0x6, 0, 14)),
应改为
		  SUNXI_FUNCTION(0x3, "uart2"),		/* RX  这一行*/
#6 2019-09-08 21:45:53
那现在可以了吗?
楼主 #7 2019-09-08 21:52:14
阿黄
已发帖子: 299
那现在可以了吗?
没硬件可以测试,明天到公司测试一下,但看起来应该没啥问题
#8 2019-09-08 22:00:42
https://github.com/torvalds/linux/blob/master/drivers/pinctrl/sunxi/pinctrl-suniv-f1c100s.c
		  SUNXI_FUNCTION(0x3, "lvds1"),		/* RX */
果然是这个惊天bug
#9 2020-08-18 08:12:48
明月照我沟渠
已发帖子: 121
&spi1 {
    status = "okay";
    dm9051@0 {
        reg = <0>;
	status = "okay";
厚脸求 "davicom,dm9051" 这个的驱动.
#10 2021-05-08 23:57:03
microxp
已发帖子: 76
好大的bug
#11 2022-11-22 15:39:14
pjrstar
十分感谢 苦思冥想了好久 在这找到了答案
