楼主 #1 2019-05-06 17:46:38
vkaoke
全志S3启动内核后,卡在fb创建过程中(主线内核4.13)
设备树的配置:
/dts-v1/;
	#address-cells = <0x1>;
	#size-cells = <0x1>;
	interrupt-parent = <0x1>;
	model = "Lichee Pi Zero";
	compatible = "licheepi,licheepi-zero", "allwinner,sun8i-v3s";
	chosen {
		ranges;
		stdout-path = "serial0:115200n8";
		framebuffer@0 {
			compatible = "allwinner,simple-framebuffer", "simple-framebuffer";
			allwinner,pipeline = "de0-lcd0";
			clocks = <0x2 0x21 0x3 0x0 0x3 0x6 0x2 0x40>;
			status = "okay";
	cpus {
		#size-cells = <0x0>;
		cpu@0 {
			compatible = "arm,cortex-a7";
			device_type = "cpu";
			reg = <0x0>;
			clocks = <0x2 0xe>;
	display-engine {
		compatible = "allwinner,sun8i-v3s-display-engine";
		allwinner,pipelines = <0x4>;
		status = "okay";
	timer {
		compatible = "arm,armv7-timer";
		interrupts = <0x1 0xd 0xf08 0x1 0xe 0xf08 0x1 0xb 0xf08 0x1 0xa 0xf08>;
	clocks {
		ranges;
		osc24M_clk {
			#clock-cells = <0x0>;
			compatible = "fixed-clock";
			clock-frequency = <0x16e3600>;
			clock-output-names = "osc24M";
			linux,phandle = <0x10>;
			phandle = <0x10>;
		osc32k_clk {
			clock-frequency = <0x8000>;
			clock-output-names = "osc32k";
			linux,phandle = <0x11>;
			phandle = <0x11>;
	soc {
		compatible = "simple-bus";
		ranges;
		clock@1000000 {
			compatible = "allwinner,sun8i-v3s-de2-clk";
			reg = <0x1000000 0x100000>;
			clocks = <0x2 0x3f 0x2 0x23>;
			clock-names = "mod", "bus";
			resets = <0x2 0x22>;
			#clock-cells = <0x1>;
			#reset-cells = <0x1>;
			linux,phandle = <0x3>;
			phandle = <0x3>;
		mixer@1100000 {
			compatible = "allwinner,sun8i-v3s-de2-mixer";
			reg = <0x1100000 0x100000>;
			clocks = <0x3 0x0 0x3 0x6>;
			clock-names = "bus", "mod";
			resets = <0x3 0x0>;
			assigned-clocks = <0x3 0x6>;
			assigned-clock-rates = <0x8f0d180>;
			linux,phandle = <0x4>;
			phandle = <0x4>;
			ports {
				port@1 {
					reg = <0x1>;
					endpoint@0 {
						reg = <0x0>;
						remote-endpoint = <0x5>;
						linux,phandle = <0x7>;
						phandle = <0x7>;
		syscon@1c00000 {
			compatible = "allwinner,sun8i-v3s-system-controller", "syscon";
			reg = <0x1c00000 0x1000>;
			linux,phandle = <0x1b>;
			phandle = <0x1b>;
		lcd-controller@1c0c000 {
			compatible = "allwinner,sun8i-v3s-tcon";
			reg = <0x1c0c000 0x1000>;
			interrupts = <0x0 0x56 0x4>;
			clocks = <0x2 0x21 0x2 0x40>;
			clock-names = "ahb", "tcon-ch0";
			clock-output-names = "tcon-pixel-clock";
			resets = <0x2 0x1b>;
			reset-names = "lcd";
			status = "okay";
			pinctrl-names = "default";
			pinctrl-0 = <0x6>;
			ports {
				port@0 {
					reg = <0x0>;
					endpoint@0 {
						reg = <0x0>;
						remote-endpoint = <0x7>;
						linux,phandle = <0x5>;
						phandle = <0x5>;
				port@1 {
					reg = <0x1>;
					endpoint@0 {
						reg = <0x0>;
						remote-endpoint = <0x8>;
						linux,phandle = <0x21>;
						phandle = <0x21>;
		dma-controller@01c02000 {
			compatible = "allwinner,sun8i-v3s-dma";
			reg = <0x1c02000 0x1000>;
			interrupts = <0x0 0x32 0x4>;
			clocks = <0x2 0x15>;
			resets = <0x2 0x6>;
			#dma-cells = <0x1>;
			linux,phandle = <0x14>;
			phandle = <0x14>;
		mmc@01c0f000 {
			compatible = "allwinner,sun7i-a20-mmc";
			reg = <0x1c0f000 0x1000>;
			clocks = <0x2 0x16 0x2 0x2d 0x2 0x2f 0x2 0x2e>;
			clock-names = "ahb", "mmc", "output", "sample";
			resets = <0x2 0x7>;
			reset-names = "ahb";
			interrupts = <0x0 0x3c 0x4>;
			status = "okay";
			pinctrl-0 = <0x9>;
			broken-cd;
			bus-width = <0x4>;
			vmmc-supply = <0xa>;
		mmc@01c10000 {
			reg = <0x1c10000 0x1000>;
			clocks = <0x2 0x17 0x2 0x30 0x2 0x32 0x2 0x31>;
			resets = <0x2 0x8>;
			interrupts = <0x0 0x3d 0x4>;
			pinctrl-0 = <0xb>;
			status = "okay";
			vqmmc-supply = <0xa>;
			mmc-pwrseq = <0xc>;
			bus-width = <0x4>;
			non-removable;
			wifi@1 {
				reg = <0x1>;
				compatible = "brcm,bcm432\n  9-fmac";
				interrupt-parent = <0xd>;
				interrupt-names = "host-wake";
				interrupts = <0x1 0xa 0x8>;
		mmc@01c11000 {
			reg = <0x1c11000 0x1000>;
			clocks = <0x2 0x18 0x2 0x33 0x2 0x35 0x2 0x34>;
			resets = <0x2 0x9>;
			interrupts = <0x0 0x3e 0x4>;
			status = "okay";
			pinctrl-0 = <0xe>;
			bus-width = <0x4>;
			non-removable;
		usb@01c19000 {
			compatible = "allwinner,sun8i-h3-musb";
			reg = <0x1c19000 0x400>;
			clocks = <0x2 0x1d>;
			resets = <0x2 0x11>;
			interrupts = <0x0 0x47 0x4>;
			interrupt-names = "mc";
			phys = <0xf 0x0>;
			phy-names = "usb";
			extcon = <0xf 0x0>;
			status = "okay";
			dr_mode = "host";
		phy@01c19400 {
			compatible = "allwinner,sun8i-v3s-usb-phy";
			reg = <0x1c19400 0x2c 0x1c1a800 0x4>;
			reg-names = "phy_ctrl", "pmu0";
			clocks = <0x2 0x38>;
			clock-names = "usb0_phy";
			resets = <0x2 0x0>;
			reset-names = "usb0_reset";
			status = "okay";
			#phy-cells = <0x1>;
			linux,phandle = <0xf>;
			phandle = <0xf>;
		usb@01c1a000 {
			compatible = "allwinner,sun8i-v3s-ehci", "generic-ehci";
			reg = <0x1c1a000 0x100>;
			interrupts = <0x0 0x48 0x4>;
			clocks = <0x2 0x1e 0x2 0x1f>;
			resets = <0x2 0x12 0x2 0x16>;
			status = "okay";
		usb@01c1a400 {
			compatible = "allwinner,sun8i-v3s-ohci", "generic-ohci";
			reg = <0x1c1a400 0x100>;
			interrupts = <0x0 0x49 0x4>;
			clocks = <0x2 0x1e 0x2 0x1f 0x2 0x39>;
			status = "okay";
		clock@01c20000 {
			compatible = "allwinner,sun8i-v3s-ccu";
			reg = <0x1c20000 0x400>;
			clocks = <0x10 0x11>;
			clock-names = "hosc", "losc";
			linux,phandle = <0x2>;
			phandle = <0x2>;
		rtc@01c20400 {
			compatible = "allwinner,sun6i-a31-rtc";
			reg = <0x1c20400 0x54>;
			interrupts = <0x0 0x28 0x4 0x0 0x29 0x4>;
		pinctrl@01c20800 {
			compatible = "allwinner,sun8i-v3s-pinctrl";
			reg = <0x1c20800 0x400>;
			interrupts = <0x0 0xf 0x4 0x0 0x11 0x4>;
			clocks = <0x2 0x25 0x10 0x11>;
			gpio-controller;
			#gpio-cells = <0x3>;
			interrupt-controller;
			#interrupt-cells = <0x3>;
			linux,phandle = <0xd>;
			phandle = <0xd>;
			i2c0 {
				pins = "PB6", "PB7";
				function = "i2c0";
				linux,phandle = <0x19>;
				phandle = <0x19>;
			uart0@0 {
				pins = "PB8", "PB9";
				function = "uart0";
				linux,phandle = <0x16>;
				phandle = <0x16>;
			uart1@0 {
				pins = "PG6", "PG7", "PG8", "PG9";
				function = "uart1";
				bias-pull-up;
				linux,phandle = <0x17>;
				phandle = <0x17>;
			uart2@0 {
				pins = "PB0", "PB1";
				function = "uart2";
				bias-pull-up;
				linux,phandle = <0x18>;
				phandle = <0x18>;
			lcd-rgb666-pins {
				pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", "PD18", "PD19", "PD20", "PD21";
				function = "lcd";
				linux,phandle = <0x6>;
				phandle = <0x6>;
			mmc0@0 {
				pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
				function = "mmc0";
				drive-strength = <0x1e>;
				bias-pull-up;
				linux,phandle = <0x9>;
				phandle = <0x9>;
			mmc1@0 {
				pins = "PG0", "PG1", "PG2", "PG3", "PG4", "PG5";
				function = "mmc1";
				bias-pull-up;
				linux,phandle = <0xb>;
				phandle = <0xb>;
			mmc2@0 {
				pins = "PC0", "PC1", "PC2", "PC3", "PC4", "PC5", "PC6", "PC7", "PC8", "PC9", "PC10";
				function = "mmc2";
				bias-pull-up;
				linux,phandle = <0xe>;
				phandle = <0xe>;
			spi0 {
				pins = "PC0", "PC1", "PC2", "PC3";
				function = "spi0";
				linux,phandle = <0x1d>;
				phandle = <0x1d>;
			wifi_en_pin {
				pins = "PB2";
				function = "gpio_out";
				linux,phandle = <0x1f>;
				phandle = <0x1f>;
			pwm1 {
				pins = "PB5";
				function = "pwm1";
				linux,phandle = <0x12>;
				phandle = <0x12>;
			pwm0 {
				pins = "PB4";
				function = "pwm0";
		timer@01c20c00 {
			compatible = "allwinner,sun4i-a10-timer";
			reg = <0x1c20c00 0xa0>;
			interrupts = <0x0 0x12 0x4 0x0 0x13 0x4>;
			clocks = <0x10>;
		watchdog@01c20ca0 {
			compatible = "allwinner,sun6i-a31-wdt";
			reg = <0x1c20ca0 0x20>;
			interrupts = <0x0 0x19 0x4>;
		pwm@1c21400 {
			compatible = "allwinner,sun8i-v3s-pwm", "allwinner,sun7i-a20-pwm";
			reg = <0x1c21400 0x400>;
			clocks = <0x10>;
			#pwm-cells = <0x3>;
			status = "okay";
			pinctrl-0 = <0x12>;
			linux,phandle = <0x1e>;
			phandle = <0x1e>;
		lradc@1c22800 {
			compatible = "allwinner,sun4i-a10-lradc-keys";
			reg = <0x1c22800 0x400>;
			interrupts = <0x0 0x1e 0x4>;
			status = "okay";
			vref-supply = <0x13>;
			button@200 {
				label = "Volume Down";
				linux,code = <0x72>;
				channel = <0x0>;
				voltage = <0x30d40>;
			button@400 {
				label = "Volume Up";
				linux,code = <0x73>;
				channel = <0x0>;
				voltage = <0x61a80>;
			button@600 {
				label = "Esc";
				linux,code = <0x1>;
				channel = <0x0>;
				voltage = <0x927c0>;
			button@800 {
				label = "Enter";
				linux,code = <0x1c>;
				channel = <0x0>;
				voltage = <0xc3500>;
			button@1000 {
				label = "Menu";
				linux,code = <0x8b>;
				channel = <0x0>;
				voltage = <0xf4240>;
		codec@01c22c00 {
			#sound-dai-cells = <0x0>;
			compatible = "allwinner,sun8i-v3s-codec";
			reg = <0x1c22c00 0x400>;
			interrupts = <0x0 0x1d 0x4>;
			clocks = <0x2 0x24 0x2 0x46>;
			clock-names = "apb", "codec";
			resets = <0x2 0x28>;
			dmas = <0x14 0xf 0x14 0xf>;
			dma-names = "rx", "tx";
			allwinner,codec-analog-controls = <0x15>;
			status = "okay";
			allwinner,audio-routing = "Headphone", "HP", "Headphone", "HPCOM", "MIC1", "Mic", "Mic", "HBIAS";
		codec-analog@01c23000 {
			compatible = "allwinner,sun8i-v3s-codec-analog";
			reg = <0x1c23000 0x4>;
			linux,phandle = <0x15>;
			phandle = <0x15>;
		serial@01c28000 {
			compatible = "snps,dw-apb-uart";
			reg = <0x1c28000 0x400>;
			interrupts = <0x0 0x0 0x4>;
			reg-shift = <0x2>;
			reg-io-width = <0x4>;
			clocks = <0x2 0x28>;
			resets = <0x2 0x31>;
			status = "okay";
			pinctrl-0 = <0x16>;
		serial@01c28400 {
			reg = <0x1c28400 0x400>;
			interrupts = <0x0 0x1 0x4>;
			reg-shift = <0x2>;
			clocks = <0x2 0x29>;
			resets = <0x2 0x32>;
			status = "okay";
			pinctrl-0 = <0x17>;
		serial@01c28800 {
			reg = <0x1c28800 0x400>;
			interrupts = <0x0 0x2 0x4>;
			reg-shift = <0x2>;
			clocks = <0x2 0x2a>;
			resets = <0x2 0x33>;
			status = "okay";
			pinctrl-0 = <0x18>;
		i2c@01c2ac00 {
			reg = <0x1c2ac00 0x400>;
			interrupts = <0x0 0x6 0x4>;
			clocks = <0x2 0x26>;
			resets = <0x2 0x2e>;
			pinctrl-0 = <0x19>;
			status = "okay";
			max30102@0x57 {
				compatible = "max30102";
				maxim,red-led-current-microamp = <0x1b58>;
				maxim,ir-led-current-microamp = <0x1b58>;
				interrupts = <0x1 0xb 0x8>;
				reg = <0x57>;
			lsm9ds1_acc_gyr@0x6A {
				compatible = "lsm9ds1_acc_gyr";
				interrupts = <0x1 0xc 0x8>;
				reg = <0x6a>;
			lsm9ds1_mag@0x1C {
				compatible = "lsm9ds1_mag";
				reg = <0x1c>;
			paj7620@0x73 {
				compatible = "pxi,paj7620";
				interrupts = <0x1 0xd 0x8>;
				reg = <0x73>;
			pmic@34 {
				compatible = "x-powers,axp209";
				reg = <0x34>;
				interrupts = <0x1 0x4 0x2>;
				#interrupt-cells = <0x1>;
				regulators {
					x-powers,dcdc-freq = <0x5dc>;
					dcdc2 {
						regulator-always-on;
						regulator-min-microvolt = <0xf4240>;
						regulator-max-microvolt = <0x162010>;
						regulator-name = "vdd-cpu";
					dcdc3 {
						regulator-max-microvolt = <0x155cc0>;
						regulator-name = "vdd-int-dll";
					ldo1 {
						regulator-min-microvolt = <0x124f80>;
						regulator-name = "vdd-rtc";
					ldo2 {
						regulator-min-microvolt = <0x2932e0>;
						regulator-max-microvolt = <0x325aa0>;
						regulator-name = "avcc";
				battery-power-supply {
					compatible = "x-powers,axp209-battery-power-supply";
					monitored-battery = <0x1a>;
				ac-power-supply {
					compatible = "x-powers,axp202-ac-power-supply";
				gpio {
					compatible = "x-powers,axp209-gpio";
					gpio-controller;
					#gpio-cells = <0x2>;
		i2c@01c2b000 {
			reg = <0x1c2b000 0x400>;
			interrupts = <0x0 0x7 0x4>;
			clocks = <0x2 0x27>;
			resets = <0x2 0x2f>;
			status = "okay";
		ethernet@1c30000 {
			compatible = "allwinner,sun8i-v3s-emac";
			syscon = <0x1b>;
			reg = <0x1c30000 0x10000>;
			interrupts = <0x0 0x52 0x4>;
			interrupt-names = "macirq";
			resets = <0x2 0xc>;
			reset-names = "stmmaceth";
			clocks = <0x2 0x1a>;
			clock-names = "stmmaceth";
			phy-handle = <0x1c>;
			phy-mode = "mii";
			status = "okay";
			allwinner,use-internal-phy;
			allwinner,leds-active-low;
			mdio {
				ethernet-phy@1 {
					compatible = "ethernet-phy-ieee802.3-c22";
					reg = <0x1>;
					clocks = <0x2 0x2b>;
					resets = <0x2 0x27>;
					phy-is-integrated;
					linux,phandle = <0x1c>;
					phandle = <0x1c>;
		spi@1c68000 {
			compatible = "allwinner,sun8i-h3-spi";
			reg = <0x1c68000 0x1000>;
			interrupts = <0x0 0x41 0x4>;
			clocks = <0x2 0x1c 0x2 0x37>;
			clock-names = "ahb", "mod";
			pinctrl-0 = <0x1d>;
			resets = <0x2 0xf>;
			status = "disabled";
		interrupt-controller@01c81000 {
			compatible = "arm,cortex-a7-gic", "arm,cortex-a15-gic";
			reg = <0x1c81000 0x1000 0x1c82000 0x1000 0x1c84000 0x2000 0x1c86000 0x2000>;
			interrupts = <0x1 0x9 0xf04>;
			linux,phandle = <0x1>;
			phandle = <0x1>;
	ahci-5v {
		compatible = "regulator-fixed";
		regulator-name = "ahci-5v";
		regulator-min-microvolt = <0x4c4b40>;
		regulator-max-microvolt = <0x4c4b40>;
		regulator-boot-on;
		enable-active-high;
		gpio = <0xd 0x1 0x8 0x0>;
	usb0-vbus {
		regulator-name = "usb0-vbus";
		enable-active-high;
		gpio = <0xd 0x1 0x9 0x0>;
	usb1-vbus {
		regulator-name = "usb1-vbus";
		regulator-boot-on;
		enable-active-high;
		gpio = <0xd 0x7 0x6 0x0>;
	usb2-vbus {
		regulator-name = "usb2-vbus";
		regulator-boot-on;
		enable-active-high;
		gpio = <0xd 0x7 0x3 0x0>;
	vcc3v0 {
		regulator-name = "vcc3v0";
		regulator-min-microvolt = <0x2dc6c0>;
		regulator-max-microvolt = <0x2dc6c0>;
		linux,phandle = <0x13>;
		phandle = <0x13>;
	vcc3v3 {
		regulator-name = "vcc3v3";
		regulator-min-microvolt = <0x325aa0>;
		linux,phandle = <0xa>;
		phandle = <0xa>;
	vcc5v0 {
		regulator-name = "vcc5v0";
	aliases {
		serial0 = "/soc/serial@01c28000";
	backlight {
		compatible = "pwm-backlight";
		pwms = <0x1e 0x1 0x7a120 0x0>;
		brightness-levels = <0x0 0x1e 0x32 0x64 0x96 0xb4 0xc8 0xfa>;
		default-brightness-level = <0x0>;
		linux,phandle = <0x20>;
		phandle = <0x20>;
	leds {
		compatible = "gpio-leds";
		sys_led {
			label = "heartbeatled";
			gpios = <0xd 0x1 0x3 0x1>;
			default-state = "on";
			linux,default-trigger = "heartbeat";
	wifi_reg_en {
		compatible = "mmc-pwrseq-simple";
		pinctrl-0 = <0x1f>;
		reset-gpios = <0xd 0x1 0x2 0x1>;
		linux,phandle = <0xc>;
		phandle = <0xc>;
	battery {
		compatible = "simple-battery";
		charge-full-design-microamp-hours = <0x86470>;
		voltage-min-design-microvolt = <0x3567e0>;
		constant-charge-current-max-microamp = <0xdbba0>;
		constant-charge-voltage-max-microvolt = <0x401640>;
		linux,phandle = <0x1a>;
		phandle = <0x1a>;
	panel {
		compatible = "urt,umsh-8596md-t", "simple-panel";
		port@0 {
			reg = <0x0>;
			backlight = <0x20>;
			endpoint@0 {
				reg = <0x0>;
				remote-endpoint = <0x21>;
				linux,phandle = <0x8>;
				phandle = <0x8>;
内核在加载到fb时,就卡住不动了,没有任何提示和报错,按任何输入也没反应,求大侠给个思路。。。。
[ 1.728632] Registering SWP/SWPB emulation handler
[ 1.737766] simple-framebuffer 47ee6000.framebuffer: framebuffer at 0x47ee6000, 0x119400 bytes, mapped to 0xc8380000
[ 1.748432] simple-framebuffer 47ee6000.framebuffer: format=x8r8g8b8, mode=600x480x32, linelength=2400
[ 1.763244] Console: switching to colour frame buffer device 75x30
[ 1.774078] simple-framebuffer 47ee6000.framebuffer: fb0: simplefb registered!
[ 1.782177] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.788798] [drm] No driver support for vblank timestamp query.
[ 1.804140] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc083a5b8)
[ 1.811520] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc08396f8)
[ 1.819187] fb: switching to sun4i-drm-fb from simple
[ 1.824424] Console: switching to colour dummy device 80x30
#2 2019-05-06 17:56:34
Re: 全志S3启动内核后,卡在fb创建过程中(主线内核4.13)
你的 bootargs 是什么?
楼主 #3 2019-05-06 18:00:01
vkaoke
你的 bootargs 是什么?
 print
arch=arm
baudrate=115200
board=sunxi
board_name=sunxi
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootarm.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_targets=fel mmc0 mmc1 usb0 pxe dhcp
bootargs=earlyprintk console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 rw
bootcmd=fatload mmc 0 $fdt_addr_r $fdtfile;fatload mmc 0 $kernel_addr_r zImage;bootz $kernel_addr_r - $fdt_addr_r
bootcmd_dhcp=run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00010:UNDI:003000;setenv bootp_arch 0xa;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci;
bootcmd_fel=if test -n ${fel_booted} && test -n ${fel_scriptaddr}; then echo '(FEL boot)'; source ${fel_scriptaddr}; fi
bootcmd_mmc0=setenv devnum 0; run mmc_boot
bootcmd_mmc1=setenv devnum 1; run mmc_boot
bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi
bootcmd_usb0=setenv devnum 0; run usb_boot
bootdelay=1
bootm_size=0x2e00000
console=115200
cpu=armv7
dfu_alt_info_ram=kernel ram 0x41000000 0x800000;fdt ram 0x41800000 0x100000;ramdisk ram 0x41B00000 0x1000000
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
efi_dtb_prefixes=/ /dtb/ /dtb/current/
fdt_addr_r=0x41800000
fdtcontroladdr=4794f2a8
fdtfile=sun8i-v3s-licheepi-zero.dtb
kernel_addr_r=0x41000000
load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi
preboot=usb start
pxefile_addr_r=0x41A00000
ramdisk_addr_r=0x41B00000
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done
scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootarm.efi; then echo Found EFI removable media binary efi/boot/bootarm.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; setenv efi_fdtfile
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
scriptaddr=0x41900000
serial#=12c000019c5d0db7
soc=sunxi
stderr=serial@01c28000
stdin=serial@01c28000
stdout=serial@01c28000
usb_boot=usb start; if usb dev ${devnum}; then setenv devtype usb; run scan_dev_for_boot_part; fi
Environment size: 4254/32764 bytes
#4 2019-05-06 18:02:23
貌似控制台切换到了 framebuffer ?
