楼主 #1 2019-04-15 17:59:43
无情一刀
已发帖子: 723
TF卡启动报错 mmc init failed with error: -110
我的sun8i.h的设置文件是下面设置的 求大神看看啊
#define CONFIG_BOOTCOMMAND "setenv bootm_boot_mode sec; " \
"load mmc 0:1 0x41000000 zImage; " \
"load mmc 0:1 0x41800000 sun8i-v3s-licheepi-zero-dock.dtb; " \
"bootz 0x41000000 - 0x41800000;"
#define CONFIG_BOOTARGS "console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw vt.global_cursor_default=0"
#2 2019-04-15 18:04:57
Re: TF卡启动报错 mmc init failed with error: -110
这块板子,这张卡烧我做的固件正常?
楼主 #3 2019-04-15 18:17:05
无情一刀
已发帖子: 723
这块板子,这张卡烧我做的固件正常?
这个卡是烧的我自己的固件
另外一张卡烧的你固件打印信息如下
U-Boot SPL 2017.01-rc2-00075-gec3f3ba-dirty (Dec 15 2017 - 14:00:51)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2017.01-rc2-00075-gec3f3ba-dirty (Dec 15 2017 - 14:00:51 +0800) Allwinner Technology
CPU: Allwinner V3s (SUN8I 1681)
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
SF: Detected mx25l12805 with page size 256 Bytes, erase size 64 KiB, total 16 MiB
dotclock: 33000kHz = 33000kHz: (1 3MHz 66) / 6
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
DRAM: 64 MiB
In: serial@01c28000
Net: phy interface0
eth0: ethernet@1c30000
starting USB...
No controllers found
Hit any key to stop autoboot: 0
reading zImage
4016104 bytes read in 641 ms (6 MiB/s)
reading sun8i-v3s-licheepi-zero-dock.dtb
Unable to read file sun8i-v3s-licheepi-zero-dock.dtb
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
楼主 #4 2019-04-15 18:23:58
无情一刀
已发帖子: 723
换了一张卡后打印的信息又不一样了
U-Boot SPL 2017.01-rc2-00073-gdd6e874-dirty (Apr 15 2019 - 02:37:00)
DRAM: 64 MiB
U-Boot 2017.01-rc2-00073-gdd6e874-dirty (Apr 15 2019 - 02:37:00 -0700) Allwinner Technology
DRAM: 64 MiB
ERROR ### Please RESET the board
#5 2019-04-15 18:28:15
用三楼那张卡烧你自己的固件试一试
#6 2019-04-15 18:59:37
雷龙发展q2852826868
已发帖子: 157
贴片式T卡 来顶一顶。支持一下
CS品牌SD NAND , ATO 小容量SLC/SPI NAND/MCP. T:13691982107,Q:2852826868
楼主 #7 2019-04-15 20:16:55
无情一刀
已发帖子: 723
用三楼那张卡烧你自己的固件试一试
都是一样的效果 没有什么区别
楼主 #8 2019-04-16 08:57:22
无情一刀
已发帖子: 723
我现在重新clone一个uboot 直接编译玩后下载后 就是同一样的结果
#9 2019-04-16 09:16:21
修改 drivers/mmc/sunxi_mmc.c
return mmc_set_mod_clk(mmchost, 24000000); //24Mhz
改为:
return mmc_set_mod_clk(mmchost, 2000000); //2Mhz
试一试
#10 2019-04-16 09:18:07
再不行就加上这个: https://whycan.cn/t_2050.html#p14059
int spl_mmc_load_image(struct spl_image_info *spl_image,
                       struct spl_boot_device *bootdev)
        struct mmc *mmc = NULL;
        u32 boot_mode;
        int err = 0;
        __maybe_unused int part;
        err = spl_mmc_find_device(&mmc, bootdev->boot_device);
        if (err)
                return err;
        int try_count = 0;
        do
                err = mmc_init(mmc);
                if (err)
#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT
                     printf("spl: mmc init failed with error: %d\n", err);
                     try_count++;
                     if(try_count > 10)
                             return err;
                break;
        }while(1);
楼主 #11 2019-04-16 09:45:38
无情一刀
已发帖子: 723
还是很难起来 我现在在uboot是 不是昨天下载的
设置时钟为2的时候打印是下面的信息
U-Boot SPL 2017.01-rc2-00073-gdd6e874-dirty (Apr 15 2019 - 18:25:24)
DRAM: 64 MiB
U-Boot 2017.01-rc2-00073-gdd6e874-dirty (Apr 15 2019 - 18:25:24 -0700) Allwinner Technology
DRAM: 64 MiB
然后代码也改了后是打印下面
U-Boot SPL 2017.01-rc2-00073-gdd6e874-dirty (Apr 15 2019 - 18:37:28)
DRAM: 64 MiB
#12 2019-04-16 09:56:16
看上面的 log 降低 MMC 的频率, spl & u-boot 都跑起来了.
再把 u-boot 里面的 DRAM 和 CPU 频率都降下来。
可以直接修改 .config 文件
DRAM 166M
CPU 800M
楼主 #13 2019-04-16 11:06:04
无情一刀
已发帖子: 723
可以直接修改 .config 文件
DRAM 166M
CPU 800M
就是配置这样两个是吧??
CONFIG_DRAM_CLK=166
CONFIG_SYS_CLK_FREQ=838860800
#14 2019-04-16 11:09:31
CONFIG_DRAM_CLK=166
CONFIG_SYS_CLK_FREQ=800000000
试一试这样.
楼主 #15 2019-04-16 11:19:29
无情一刀
已发帖子: 723
CONFIG_DRAM_CLK=166
试一试这样.
无语了 还是这样
U-Boot SPL 2017.01-rc2-00073-gdd6e874-dirty (Apr 15 2019 - 20:13:26)
DRAM: 64 MiB
U-Boot 2017.01-rc2-00073-gdd6e874-dirty (Apr 15 2019 - 20:13:26 -0700) Allwinner Technology
DRAM: 64 MiB
#16 2019-04-16 11:29:14
这有点尴尬,烧我的固件不会酱紫?
楼主 #17 2019-04-16 11:31:55
无情一刀
已发帖子: 723
这有点尴尬,烧我的固件不会酱紫?
我都按照上面的修改了
U-Boot SPL 2017.01-rc2-00073-gdd6e874-dirty (Apr 15 2019 - 20:25:02)
DRAM: 64 MiB
DRAM: 64 MiB
DRAM: 64 MiB
DRAM: 64 MiB
DRAM: 64 MiB
DRAM: 64 MiB
DRAM: 64 MiB
就那个代码里面一直在读取了
楼主 #18 2019-04-16 11:39:06
无情一刀
已发帖子: 723
这有点尴尬,烧我的固件不会酱紫?
下载你的没有问题
#19 2019-04-16 12:14:30
无情一刀 wrote:
这有点尴尬,烧我的固件不会酱紫?
下载你的没有问题
那单独烧我固件的 uboot 试一试?
楼主 #20 2019-04-16 12:33:22
无情一刀
已发帖子: 723
无情一刀 wrote:
这有点尴尬,烧我的固件不会酱紫?
下载你的没有问题
那单独烧我固件的 uboot 试一试?
好的 下午试试
我刚才烧写刚下载的uboot 打印的信息是下面 这个新的uboot 我就修改了DRAM和CU时钟
U-Boot 2017.01-rc2-00073-gdd6e874-dirty (Apr 15 2019 - 20:56:13 -0700) Allwinner Technology
DRAM: 64 MiB
SF: unrecognized JEDEC id bytes: c2, 20, 18
*** Warning - spi_flash_probe() failed, using default environment
In: serial@01c28000
Net: No ethernet found.
starting USB...
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
reading /sun8i-v3s-licheepi-zero.dtb
11872 bytes read in 25 ms (462.9 KiB/s)
starting USB...
USB is stopped. Please issue 'usb start' first.
starting USB...
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
#21 2019-04-16 12:44:22
上面这个 uboot 启动了,应该是可以进入命令行状态吧
楼主 #22 2019-04-16 13:37:41
无情一刀
已发帖子: 723
无情一刀 wrote:
这有点尴尬,烧我的固件不会酱紫?
下载你的没有问题
那单独烧我固件的 uboot 试一试?
DRAM: 64 MiB
In: serial@01c28000
Net: phy interface0
starting USB...
reading zImage
Unable to read file zImage
12545 bytes read in 27 ms (453.1 KiB/s)
#23 2019-04-16 13:41:48
那可以你在这个基础上改吧.
楼主 #24 2019-04-16 15:28:49
无情一刀
已发帖子: 723
那可以你在这个基础上改吧.
下载新uboot 烧写进去了uboot是起来 就是一直这样了
U-Boot 2017.01-rc2-00073-gdd6e874-dirty (Apr 16 2019 - 00:23:47 -0700) Allwinner Technology
DRAM: 64 MiB
In: serial@01c28000
Net: phy interface0
starting USB...
Scanning mmc 0:1...
11868 bytes read in 25 ms (462.9 KiB/s)
starting USB...
starting USB...
BOOTP broadcast 1
DHCP client bound to address 192.168.0.168 (4 ms)
*** Warning: no boot file name; using 'C0A800A8.img'
Using ethernet@1c30000 device
TFTP from server 192.168.1.1; our IP address is 192.168.0.168
Filename 'C0A800A8.img'.
Load address: 0x41000000
Loading: T T
#25 2019-04-16 15:30:34
楼主 #26 2019-04-16 15:36:24
无情一刀
已发帖子: 723
步骤没有错的 git clone https://github.com/Lichee-Pi/u-boot.git -b v3s-spi-experimental
#27 2019-04-16 15:39:58
第一个分区缺 sun8i-v3s-licheepi-zero.dtb, zImage 文件?
楼主 #28 2019-04-17 12:03:00
无情一刀
已发帖子: 723
至今没有找到答案 虽然可以跑起来了
我昨天是从新下载了一个uboot带spi 然后在sun8i.h里面设置了TF启动 后面就直接烧写TF卡中 就起来了 ,
我不知道是不是uboot直接cp过来原因的
