楼主 # 2026-05-08 20:03:54
QL2017
F133 FLASH容量问题
各位大佬,之前用25Q256一直烧录不成功,所以能用25Q128吗,感觉容量有点不够吧
#1 2026-05-08 20:27:22
Re: F133 FLASH容量问题
要看烧录的时候串口终端的日志。
楼主 #2 2026-05-08 21:21:38
QL2017
Re: F133 FLASH容量问题
[33]HELLO! BOOT0 is starting!
[35]BOOT0 commit : 88480af
[38]set pll start
[40]periph0 has been enabled
[43]set pll end
[44][pmu]: bus read error
[47]board init ok
[48]ZQ value = 0x2d
[50]get_pmu_exist() = -1
[53]ddr_efuse_type: 0xa
[55]trefi:7.8ms
[57][AUTO DEBUG] single rank and full DQ!
[61]ddr_efuse_type: 0xa
[63]trefi:7.8ms
[65][AUTO DEBUG] rank 0 row = 13
[68][AUTO DEBUG] rank 0 bank = 4
[71][AUTO DEBUG] rank 0 page size = 2 KB
[75]DRAM BOOT DRIVE INFO: V0.33
[78]DRAM CLK = 528 MHz
[80]DRAM Type = 2 (2:DDR2,3:DDR3)
[83]DRAMC read ODT off.
[86]DRAM ODT off.
[87]ddr_efuse_type: 0xa
[90]DRAM SIZE =64 M
[92]dram_tpr4:0x0
[94]PLL_DDR_CTRL_REG:0xf8002b00
[96]DRAM_CLK_REG:0xc0000000
[99][TIMING DEBUG] MR2= 0x0
[103]DRAM simple test OK.
[106]dram size =64
[108]card no is 0
[109]sdcard 0 line count 4
[112][mmc]: mmc driver ver 2021-04-2 16:45
[121][mmc]: Wrong media type 0x0
[124][mmc]: Try SD card 0
[134][mmc]: HSSDR52/SDR25 4 bit
[137][mmc]: 50000000 Hz
[139][mmc]: 30360 MB
[141][mmc]: SD/MMC 0 init OK!!!
[189]Loading boot-pkg Succeed(index=0).
[193]Entry_name = opensbi
[196]Entry_name = u-boot
[200]Entry_name = dtb
[203]mmc not para
[204]Jump to second Boot.
OpenSBI auto-t113-linux-V0.8-3-ge39e937
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
| | | |_ __ ___ _ __ | (___ | |_) || |
| | | | '_ \ / _ \ '_ \ \___ \| _ < | |
| |__| | |_) | __/ | | |____) | |_) || |_
\____/| .__/ \___|_| |_|_____/|____/_____|
|_|
Platform Name : T-HEAD Xuantie Platform
Platform HART Features : RV64ACDFIMSUVX
Platform Max HARTs : 1
Current Hart : 0
Firmware Base : 0x41fc0400
Firmware Size : 75 KB
Runtime SBI Version : 0.2
MIDELEG : 0x0000000000000222
MEDELEG : 0x000000000000b1ff
PMP0 : 0x0000000041fc0000-0x0000000041fdffff (A)
PMP1 : 0x0000000040000000-0x000000007fffffff (A,R,W,X)
PMP2 : 0x0000000080000000-0x00000000bfffffff (A,R,W,X)
PMP3 : 0x0000000000020000-0x0000000000027fff (A,_H¨H¨Ӓ½½с2018.07-ge987def5 (Nov 07 2022 - 03:11:27 +0000) Allwinner Technology
[00.289]DRAM: 64 MiB
[00.291]Relocation Offset is: 01eea000
[00.296]secure enable bit: 0
[00.299]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
sunxi flash map init
SPI ALL: ready
[00.309]flash init start
[00.311]workmode = 17,storage type = 1
try card 2
set card number 2
get card number 2
[00.319][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
[00.325][mmc]: get sdc_type fail and use default host:tm4.
[00.331][mmc]: Is not Boot mode!
[00.334][mmc]: SUNXI SDMMC Controller Version:0x50310
[00.345][mmc]: Try SD card 2
[00.350][mmc]: mmc 2 cmd timeout 100 status 100
[00.354][mmc]: smc 2 err, cmd 8, RTO
[00.358][mmc]: mmc 2 close bus gating and reset
[00.363][mmc]: mmc 2 cmd timeout 100 status 100
[00.367][mmc]: smc 2 err, cmd 55, RTO
[00.370][mmc]: mmc 2 close bus gating and reset
[00.374][mmc]: Try MMC card 2
[00.383][mmc]: mmc 2 cmd timeout 100 status 100
[00.387][mmc]: smc 2 err, cmd 1, RTO
[00.391][mmc]: mmc 2 close bus gating and reset
[00.395][mmc]: Card did not respond to voltage select!
[00.400][mmc]: SD/MMC 2 init error!
[00.405][mmc]: mmc init product failed
MMC init failed
try emmc fail
[00.412]sunxi-spinand: AW SPINand MTD Layer Version: 1.8 20220106
[00.418]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.11 20211217
[00.426]sunxi-spinand-phy: request spi0 gpio ok
[00.430]sunxi-spinand-phy: request general tx dma channel ok!
[00.436]sunxi-spinand-phy: request general rx dma channel ok!
[00.441]sunxi-spinand-phy: set spic0 clk to 20 Mhz
[00.446]sunxi-spinand-phy: init spic0 clk ok
[01.450]sunxi-spinand-phy: read id failed : -110
try nand fail
[01.458]sunxi_upper_lock, invalid address!
[01.467]spi sunxi_slave->max_hz:100000000
[02.450]Sample mode:1 start:0 end:51 right_sample_delay:0x19
SF: Detected w25q256 with page size 256 Bytes, erase size 64 KiB, total 32 MiB
[02.718][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
[02.724][mmc]: get sdc_type fail and use default host:tm1.
[02.730][mmc]: can't find node "mmc0",will add new node
[02.735][mmc]: fdt err returned <no error>
[02.738][mmc]: Using default timing para
[02.742][mmc]: SUNXI SDMMC Controller Version:0x50310
[02.761][mmc]: card_caps:0x3000000a
[02.764][mmc]: host_caps:0x3000003f
[02.767]line:703 init_clocks
[02.770]init_clocks:finish
[02.773]drv_disp_init
[02.782]get flash lcd idx 0
request pwm success, pwm7:pwm7:0x2000c00.
[02.791]HDMI 2.0 driver init start!
[02.795]drv_disp_init finish
[02.798]boot_gui_init:start
[02.801]set disp.dev2_output_type fail. using defval=0
[02.806]disp 0, clk: pll(420000000),clk(420000000),dclk(70000000) dsi_rate(150000000)
clk real:pll(420000000),clk(420000000),dclk(105000000) dsi_rate(150000000)
[02.842]switch device: sel=0, type=1, mode=4, format=0, bits=0, eotf=4, cs=260
[02.849]set disp.fb0_rot_used fail. using defval=0
[03.015]set disp.fb0_rot_degree fail. using defval=0
[03.023]boot_gui_init:finish
[03.025]Loading Environment from SUNXI_FLASH... OK
[03.030]try to burn key
[03.032]out of usb burn from boot: not need burn key
Hit any key to stop autoboot: 0
sunxi work mode=0x11
run card sprite
[03.044]try sprite_led_gpio config
[03.047]sprite_led_gpio start
[03.050]sunxi sprite begin
firmware name <NULL>
img start = 0x120
try to read mmc start 288
read mmc ok
[03.062]firmware probe ok
[03.065]fetch download map
DOWNLOAD MAP DUMP*
total download part 5
[03.075]LCD open finish
download part[0] name :boot-resource
download part[0] download file :BOOT-RESOURCE_FE
download part[0] verify file :VBOOT-RESOURCE_F
download part[0] lenlo :0x100
download part[0] addrlo :0x20
download part[0] encrypt :0x0
download part[0] verify :0x1
download part[1] name :env
download part[1] download file :ENV_FEX000000000
download part[1] verify file :VENV_FEX00000000
download part[1] lenlo :0x100
download part[1] addrlo :0x120
download part[1] encrypt :0x0
download part[1] verify :0x1
download part[2] name :env-redund
download part[2] download file :ENV_FEX000000000
download part[2] verify file :VENV_FEX00000000
download part[2] lenlo :0x100
download part[2] addrlo :0x220
download part[2] encrypt :0x0
download part[2] verify :0x1
download part[3] name :boot
download part[3] download file :BOOT_FEX00000000
download part[3] verify file :VBOOT_FEX0000000
download part[3] lenlo :0x3c00
download part[3] addrlo :0x320
download part[3] encrypt :0x0
download part[3] verify :0x1
download part[4] name :rootfs
download part[4] download file :ROOTFS_NOR_FEX00
download part[4] verify file :VROOTFS_NOR_FEX0
download part[4] lenlo :0x3000
download part[4] addrlo :0x3f20
download part[4] encrypt :0x0
download part[4] verify :0x1
[03.205]fetch mbr
the 0 mbr table is ok
MBR DUMP****
total mbr part 6
part[0] classname :DISK
part[0] user_type :32768
part[0] keydata :0
part[0] ro :0
part[1] name :env
part[1] classname :DISK
part[1] user_type :32768
part[1] keydata :0
part[1] ro :0
part[2] classname :DISK
part[2] user_type :32768
part[2] keydata :0
part[2] ro :0
part[3] name :boot
part[3] classname :DISK
part[3] user_type :32768
part[3] keydata :0
part[3] ro :0
part[4] classname :DISK
part[4] user_type :32768
part[4] keydata :0
part[4] ro :0
part[5] name :UDISK
part[5] classname :DISK
part[5] addrlo :0x6f20
part[5] lenlo :0x0
part[5] user_type :33024
part[5] keydata :0
part[5] ro :0
MBR DUMP****
total mbr part 6
part[0] user_type :0x8000
part[0] keydata :0x0
part[0] ro :0x0
part[1] name :env
part[1] user_type :0x8000
part[1] keydata :0x0
part[1] ro :0x0
part[2] user_type :0x8000
part[2] keydata :0x0
part[2] ro :0x0
part[3] name :boot
part[3] user_type :0x8000
part[3] keydata :0x0
part[3] ro :0x0
part[4] user_type :0x8000
part[4] keydata :0x0
part[4] ro :0x0
part[5] name :UDISK
part[5] lenlo :0x0
part[5] user_type :0x8100
part[5] keydata :0x0
part[5] ro :0x0
[03.406]begin to erase flash
common1(partition3) need it, here is a weak func
total part: 7
mbr 0, 20, 8000
boot-resource 1, 100, 8000
env 2, 100, 8000
env-redund 3, 100, 8000
boot 4, 3c00, 8000
rootfs 5, 3000, 8000
UDISK 6, 0, 8100
need erase flash: 1
[03.429]read item0 copy0
[03.432][mmc]: MMC: block number 0x3008 exceeds max(0x0)
read first backup failed in fun sunxi_sprite_mmc_secread line 466
[03.442][mmc]: MMC: block number 0x3008 exceeds max(0x0)
[03.453]unknown error happen in item 0 read
[03.457]get secure storage map err
secure storage init err
no part need to protect user data
erase size: 65536 ,sector size: 65536
total 512 sectors, erase index 0
total 512 sectors, erase index 16
total 512 sectors, erase index 32
total 512 sectors, erase index 48
total 512 sectors, erase index 64
total 512 sectors, erase index 80
total 512 sectors, erase index 96
total 512 sectors, erase index 112
total 512 sectors, erase index 128
total 512 sectors, erase index 144
total 512 sectors, erase index 160
total 512 sectors, erase index 176
total 512 sectors, erase index 192
total 512 sectors, erase index 208
total 512 sectors, erase index 224
total 512 sectors, erase index 240
total 512 sectors, erase index 256
total 512 sectors, erase index 272
total 512 sectors, erase index 288
total 512 sectors, erase index 304
total 512 sectors, erase index 320
total 512 sectors, erase index 336
total 512 sectors, erase index 352
total 512 sectors, erase index 368
total 512 sectors, erase index 384
total 512 sectors, erase index 400
total 512 sectors, erase index 416
total 512 sectors, erase index 432
total 512 sectors, erase index 448
total 512 sectors, erase index 464
total 512 sectors, erase index 480
total 512 sectors, erase index 496
[94.071]successed in erasing flash
SF: write offset not multiple of erase size
write primary GPT success
spinor: skip backup GPT
[94.087]update partition map
GUID Partition Table Entry Array CRC is wrong: 0xeadcc20a != 0xb2aa7578
part_get_info_efi: ERROR: Invalid GPT
GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
part_get_info_efi: ERROR: Invalid Backup GPT
[94.112]begin to download part
[94.115]begin to download part boot-resource
partdata hi 0x0
partdata lo 0x14000
sparse: bad magic
[94.272]successed in writting part boot-resource
origin_verify value = e6f75b5c, active_verify value = e6f75b5c
[94.286]successed in verify part boot-resource
[94.291]successed in download part boot-resource
[94.295]begin to download part env
partdata hi 0x0
partdata lo 0x20000
sparse: bad magic
[94.527]successed in writting part env
origin_verify value = 82bf05f6, active_verify value = 82bf05f6
[94.540]successed in verify part env
[94.543]successed in download part env
[94.547]begin to download part env-redund
partdata hi 0x0
partdata lo 0x20000
sparse: bad magic
[94.780]successed in writting part env-redund
[94.793]successed in verify part env-redund
[94.797]successed in download part env-redund
[94.801]begin to download part boot
partdata hi 0x0
partdata lo 0x6c0800
sparse: bad magic
