楼主 #1 2018-06-08 13:18:28
guanglun
已发帖子: 44
Nano f1c100s linux固件mplayer播放视频报错
Nano f1c100s 使用网盘中linux固件:Nano_tf_800480.dd,进入系统后执行mplayer /test/fuchouzhe.mp4,屏幕无反应,现象如下:
# mplayer /test/fuchouzhe.mp4
MPlayer 1.3.0-4.8.3 (C) 2000-2016 MPlayer Team
Playing /test/fuchouzhe.mp4.
libavformat version 57.25.100 (internal)
libavformat file format detected.
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x7f2af8]Protocol name not provided, cannot determine if input is local or a network protocol, buffers and access patterns cannot be configured optimally without knowing the protocol
[lavf] stream 0: video (mpeg4), -vid 0
[lavf] stream 1: audio (aac), -aid 0, -alang und
VIDEO:  [MP4V]  800x480  24bpp  18.000 fps  383.7 kbps (46.8 kbyte/s)
Could not find a UTF-8 locale,
character keys beyond Latin-1 will not be handled.
vo: couldn't open the X11 display ()!
VO XOverlay need a subdriver
[VO_SDL] SDL initialization failed: Unable to open mouse.
notice: Can't open /dev/tty: No such device or address
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
libavcodec version 57.24.102 (internal)
Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
Clip info:
 major_brand: isom
 minor_version: 1
 compatible_brands: isom
 creation_time: 2018-06-04 07:27:46
 encoder: FormatFactory : www.pcfreetime.com
Load subtitles in /test/
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 22050 Hz, 2 ch, floatle, 64.8 kbit/4.59% (ratio: 8098->176400)
Selected audio codec: [ffaac] afm: ffmpeg (FFmpeg AAC (MPEG-2/MPEG-4 Audio))
AO: [oss] 22050Hz 2ch s16le (2 bytes per sample)
Starting playback...
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
Movie-Aspect is 1.67:1 - prescaling to correct movie aspect.
[swscaler @ 0xa36cc0]bicubic scaler, from yuv420p to bgra using C
[swscaler @ 0xa36cc0]No accelerated colorspace conversion found from yuv420p to bgra.
[swscaler @ 0xa36cc0]using unscaled yuv420p -> bgra special converter
VO: [fbdev] 800x480 => 800x480 BGRA
Can't put VSCREENINFO: Invalid argument
FATAL: Cannot initialize video driver.
MPlayer interrupted by signal 2 in module: decode video
看起来是屏幕的问题,执行echo 123 >/dev/fb0屏幕无反应,只有Log信息和光标显示在LCD上,求助大侠解决思路!
#2 2018-06-08 13:36:38
Re: Nano f1c100s linux固件mplayer播放视频报错
你这个mplayer是软解还是硬解?
#3 2018-06-08 14:00:58
满屏都是这个错误:
看起来 framebuffer驱动程序未实现 VSCREENINFO 接口?
#4 2020-09-17 22:55:16
muyi7
刚入坑,碰到同样的问题,请问有没有解决了的朋友分享下经验,谢谢!
#5 2021-04-23 11:17:50
542396750@qq.com
已发帖子: 163
你好,我也遇到这个问题
我想用buildroot里面的mplayer测试播放mp4
