楼主 # 2024-08-20 18:06:52
让我静静躺赢
T113 添加 openssh 编译错误
libressl-api-compat.c: In function ‘RSA_get0_key’:
libressl-api-compat.c:234:9: error: dereferencing pointer to incomplete type ‘RSA {aka const struct rsa_st}’
*n = r->n;
libressl-api-compat.c: In function ‘RSA_set0_key’:
libressl-api-compat.c:246:8: error: dereferencing pointer to incomplete type ‘RSA {aka struct rsa_st}’
if ((r->n == NULL && n == NULL) || (r->e == NULL && e == NULL))
libressl-api-compat.c: In function ‘RSA_meth_free’:
libressl-api-compat.c:532:20: error: dereferencing pointer to incomplete type ‘RSA_METHOD {aka struct rsa_meth_st}’
free((char *)meth->name);
libressl-api-compat.c: In function ‘RSA_meth_dup’:
libressl-api-compat.c:547:31: error: dereferencing pointer to incomplete type ‘RSA_METHOD {aka const struct rsa_meth_st}’
if ((copy->name = strdup(meth->name)) == NULL) {
libressl-api-compat.c: In function ‘EVP_PKEY_get0_RSA’:
libressl-api-compat.c:611:10: error: dereferencing pointer to incomplete type ‘EVP_PKEY {aka struct evp_pkey_st}’
if (pkey->type != EVP_PKEY_RSA) {
libressl-api-compat.c: In function ‘RSA_meth_get_finish’:
libressl-api-compat.c:575:1: warning: control reaches end of non-void function [-Wreturn-type]
libressl-api-compat.c:616:1: warning: control reaches end of non-void function [-Wreturn-type]
make[5]: *** [Makefile:99: libressl-api-compat.o] Error 1
make[5]: Leaving directory ‘/home/lc1/Desktop/oet/t113s3/proj_100/sourcecode/tina-d1-h/out/t113-100ask/compile_dir/target/openssh-without-pam/openssh-8.0p1/openbsd-compat’
make[4]: *** [Makefile:165: openbsd-compat/libopenbsd-compat.a] Error 2
make[4]: Leaving directory ‘/home/lc1/Desktop/oet/t113s3/proj_100/sourcecode/tina-d1-h/out/t113-100ask/compile_dir/target/openssh-without-pam/openssh-8.0p1’
make[3]: *** [Makefile:269: /home/lc1/Desktop/oet/t113s3/proj_100/sourcecode/tina-d1-h/out/t113-100ask/compile_dir/target/openssh-without-pam/openssh-8.0p1/.built] Error 2
make[3]: Leaving directory ‘/home/lc1/Desktop/oet/t113s3/proj_100/sourcecode/tina-d1-h/package/network/openssh’
make[2]: *** [package/Makefile:193: package/network/openssh/compile] Error 2
make[2]: Leaving directory ‘/home/lc1/Desktop/oet/t113s3/proj_100/sourcecode/tina-d1-h’
make[1]: *** [package/Makefile:189: /home/lc1/Desktop/oet/t113s3/proj_100/sourcecode/tina-d1-h/out/t113-100ask/staging_dir/target/stamp/.package_compile] Error 2
make[1]: Leaving directory ‘/home/lc1/Desktop/oet/t113s3/proj_100/sourcecode/tina-d1-h’
make: *** [/home/lc1/Desktop/oet/t113s3/proj_100/sourcecode/tina-d1-h/build/toplevel.mk:306: world] Error 2
[2]+ Done $T/tools/build/buildserver --path $T 2> /dev/null 1>&2
楼主 #1 2024-08-21 16:51:55
让我静静躺赢
Re: T113 添加 openssh 编译错误
/home/yk/t113s/Tina-Linux-2023/package/network/openssh/Makefile
PKG_VERSION:=8.0p1 ----> openssh-9.8p1
主要原因 openssl1.1.0i 与 openssh-8.0p1 不匹配
#2 2024-08-21 17:28:00
memory
已发帖子: 718
问题解决了吗?
#3 2024-08-27 14:48:58
cjia
同求,我也遇到了这个问题,但是当时测试再d1s上是没有这个问题的。
楼主 #4 2024-08-27 14:53:17
让我静静躺赢
解决了 PKG_VERSION:=8.9p1 就OK了
#5 2024-12-17 17:39:55
mixnavy
这个报错的原因是
libssl 没有使能 rsa 支持
需要在buildroot 的 libraries 里使能
make menuconfig > Libraries > SSL > libopenssl > Enable RSA algorithm support ,就可以编译了
同时,如 让我静静躺赢 所说,openssl 8.0p1,与 libssl 的 1.1.0i 版本不兼容, 会有其他的编译错误,我 改成 8.9p1 和 9.1p1 都可以编译通过
网上很多说需要 apt install 特定版本的 libopenssl,是错误的,不应该这样做
