楼主 # 2024-06-25 08:15:26
ubuntu
已发帖子: 342
请问T113 LVGL DEMO G2D_CMD_BITBLT_H failed: Operation not permitte是什么问题?
# chmod +x /tmp/lvgl_sunxifb && /tmp/lvgl_sunxifb 0
wh=1200x1920, vwh=1200x3840, bpp=32, rotated=0
Turn on double buffering.
Turn on 2d hardware acceleration.
Turn on 2d hardware acceleration rotate.
Error: sunxifb_g2d_blit_to_fb G2D_CMD_BITBLT_H failed: Operation not permitted
sunxifb_g2d_blit_to_fb src[phy=0x1200000 format=0 alpha=255 wh=[1200 1920] clip=[0 0 1200 1920]] dst=[phy=(nil) format=0 wh=[1200 3840] clip=[0 0 1200 1920]]
sunxifb_g2d_blit_to_fb src[phy=0x1200000 format=0 alpha=255 wh=[1200 1920] clip=[0 0 1200 1920]] dst=[phy=(nil) format=0 wh=[1200 3840] clip=[0 1920 1200 1920]]
#1 2024-06-25 08:30:55
Re: 请问T113 LVGL DEMO G2D_CMD_BITBLT_H failed: Operation not permitte是什么问题?
大概是 g2d_driver_enh.h 这个头文件与驱动不匹配,检查一下
参考:LVGL8打开G2D报错
#2 2025-02-18 08:42:26
树莓学LINUX
已发帖子: 131
老兄解决了吗,我也修改了头文件,但是好像错误并没有被修改
